risktaker99
GE gas Dryer squeals
8 posts in this topic
Model #DPSQ475GT6WW
I can't seem to find the part # for the rear bearing on the drum. Should I also replace the glides as well?
Thanks for your help!!
GE part number WE25M40 - it comes as a complete kit, the plastic bearing doesn't seem to be available on its own. I'd replace the glides while you're at it.
Thanks for help...I have taken the dryer apart. The drum support(the part that holds the glides) is not in great shape. What is the part # for it?
Thanks.
...another related question. I found the part # for the two (2) "grey" slides which is #9359999. However, I couldn't find the part # for the two (2) "white"slides. Could you tell me what it is?
Thanks for help.. I just ordered the parts. The drum support is on back order. I think I'll put in the rear bearing and reassemble the dryer so we can use it until the backordered part arrives.
Do I have to put any grease on the new shaft/bearing?
Thanks.
No grease, just clean up the shaft with some emery cloth.
