New Guy
Amana ALW480DAW Washer - Loud noise during spin cycle
6 posts in this topic
    About two days ago, my Amana alw480daw washing machine has started acting up during the spin cycle. The regular wash cycle goes just fine, but during the spin cycle, rather than actually spinning, the tub moves very little while the machine makes a very loud ratcheting sound. To figure out what was causing the noise, I removed the front panel and let the machine do its thing while I watched below. I quickly found out where exactly the noise was originating from, but I'm clueless as to how to proceed from here. I've attached a picture of the mechanism where all the noise is coming from. To my newbie eyes, it looks like it's doing what it's supposed to, but that can't possibly be right. During the wash cycle, the belt spins the shaft counterclockwise, and the top and bottom piece in the center of the photo grip each other, like it's obviously supposed to. During the spin cycle, the shaft is rotated the opposite direction, and the two pieces slip past each other, producing that loud sound.
Some extra info in case it helps:
    -The interior has no obvious signs of rust or leakage
    -The belt is breaking/shredding in a couple of spots. It still appears to be working as intended, but I plan on replacing it regardless of whether it's the cause of this particular problem or not.
    -When I try to spin the tub by hand, it doesn't move freely. I have to grip it with both hands to get it moving in either direction. I don't recall whether it's supposed to or not, though, but I figured I should mention it here just in case.
    I'm sure I would be able to replace any needed parts on my own as long as the procedure is not overly complicated, but other than replacing a broken drain hose, I don't have any experience repairing a washing machine. If anyone has a solution, please explain it with this in mind. Thanks.
That part you took the picture of is the HELIX. You will need to replace it, it's fairly straightforward.
    I did notice that it's a bit worn, but I figured the noise from the helix could have been just a symptom of the problem and not the cause. Alright, so I've got to replace the helix. Do I also have to get a new transmission drive pulley to go with it?
It might be a good idea to replace the transmission pulley while you are at it.
    Okay, I got all the parts today (helix, belt, and pulley) and managed to figure out how to get them into the machine. It was alot more work than I was hoping it would be, since I had to disassemble pretty much the entire thing to get to where the parts go, but I got everything in there and put it back together just fine. I tested it out and, so far, it works perfectly. The spin cycle is back to normal. Just wanted to say thanks for pointing me in the right direction.
You're welcome, that's what we're here for.
