  • Announcements
Marcfb
Maytag WU103
7 posts in this topic
I am about to replace the shaft and bearing assembly in the pump of my Maytag WU103 dishwasher.  The old bearing assembly was destroyed and I tapped it out of the fiberglass housing. I need to know if there is a special way of installing the new bearing assembly. Do I just tap it back in or is there some procedure. I need some words of wisdom.
Marc
Which part(s) did you remove and need to replace?
The shaft and bearing assembly were frozen. I taped it out and cleaned the are where it goes in the fiberglass housing. Now I need to reinstall the new shaft and bearing assembly. Not sure how to that without destroying the housing or the new shaft and bearing assembly.
Marc
Did you notice that I had a link in my previous post?  Notice now and then tell me which item number you're talking about.
Sorry, I thought you knew which part I was talking about. It is the SHAFT AND BEARING ASSY. Repairclinic calls it as their part # 737792. Maytag calls it a 900896.
Hope that is what you wanted.
Marc
:shock:
Can you even get that part anymore?  Looks like they're showing a picture of a used bearing!
