jhruzek
4th cheap plastic handle or operator error? Whirlpool Duet
17 posts in this topic
I need to know if I am installing these handles incorrectly.  There are only 2 screws and I have snugged them down, not over torqued them.  What gives?
is it really hard to open the door? if not then maybe she is yanking on the handle too hard
It doesn't seem to be that hard.  I would not think it should break these handles, but they are just plastic.  It seems that the design of the handle of the dryer was much better thought out.  Why they are different makes no sense to me.  I have found on another board that others are having the same problem.  I wonder, if I can put a strip of metal to reinforce the handle between the screws, if that would spread out the force of opening the door and have the handle last longer?
Hi,
I know what I would do if it was my wife, but that's up to you. :)
All kidding aside I don't see that many broken handles on the Duets.
The dryer does have a better design though and yes it would have been nice if they would have used it on the washer too.
It definitely is not worth the pain to respond to her in the manner you have implied!  Seriously, do you think that adding a strip of metal would be of any help?  I do not think a washer would be enough.
Is the latching mechanism adjustable as to the amount of force needed to open the washer?  If so, maybe it is set too strong and that is what breaks the handles???
^ actually it is. the catches come in different thicknesses of metal. but if you make it too easy to open the clothes could push it open and machine would cut off
How do I tell which is installed?  If original factory installed, are they all the same from the factory?  What would be the part number for the next one down?
the metal part of the catch is painted a different  color and the size is stamped on it. there is a whirlpool part# that has 3 or 4 different sizes in one bag.
The Duet is front-load which implies it has a door locking mechanism when the machine is running.  What's the chance your wife is yanking on the door to throw in some last-minute items AFTER the door has locked?
Along that line of reasoning.....maybe the door handle was intentionally designed as the weak point so people wouldn't break the internal latching mechanism?
Finally, if my first idea is NOT true, what is the chance that the better-designed dryer handle will fit on the washer?  I dunno....I don't own Duets.
My Duet washer would be around 6 years old now and still has its original door handle....never had a problem with the washer or handle....but I am very careful with it.....how many are in the family and use the washer???  Is the door out of adjustment?  Does the door latch line up....??  Four broken door handles in what time frame? Sounds like user mis-use to me but we do not know how it is being used by how many people over what time frame either....just asnwering the question that was asked....and asking questions to get a better feel of the situation.
for the last five days i thought this thread was about a duet dryer since they are the ones that break handles. disregard all my post above. hah
I think wagstdy is on to something.  We have a new maid and I bet she doesn't realize that the door locks.  I will try another handle before trying anything else.  Now, I just need to translate don't break the ##@!#@% handle into Spanish!
Also, when the Washer is Paused or Stopped, the Door won't UN-lock until the Motor Speed reaches 0 RPM
Luckily (for you) we cater to those people who don't speak English here in America.  There is undoubtedly a section in your owner's manual written in Spanish so find the part in the English section that says something like, "Don't try to open the door when the 'door lock' light is lit" and then find the corresponding page(s)/picture(s) in the Spanish section and use "pointy-talky" with the maid.
I now noticed a crack in the clear plastic on the hinge side.  I definitely am leaning toward operator abuse of the washer.
""I definitely am leaning toward operator abuse of the washer.""
If the door is being pulled on hard enough to break door handles and crack the plastic on the door think of the damage being done to the door lock itself....surprised it has not been broken already....:?
