kyelzbub
Help, freezer turning to ice block
6 posts in this topic
I have a Whirlpool upright freezer and it is collecting frost and growing into an ice block overnight. I had this problem last year, and thought it might be a gasket issue, so I put some weather stripping around the freezer face, just a bit outside of the door's width when closed. This acted as an exterior gasket and fixed the issue. Well, it has started again. When ever I open the freezer, everything is frozen, but at the top of the door frame, there are always water droplets hanging that are not frozen. Is this a sure sign of something specific, and is there a fix?
Sounds like you might need to replace the door gasket.
The door gasket looks as though it is actually anchored behind the door panel. Does it sound correct that I would have to unscrew the door panel from the inside, and set the gasket underneath the inside door panel or am I totally off here?
We havn't a clue without the model number to see what you have.
Thank you Samurai, this should be all the information I need to fix my freezer. You are definitely the Master.
