tedd
Frigidaire Gas Range w/ Electric Starter
3 posts in this topic
Turned off breaker to range, when I turned it back on, got error code F1.  According to the manual, by pushing the "Clear" button, it will clear the error  There is only a "Cancel" button which I pushed, but it did not reset the system.
Any help would be appreciated; I'm located in Marietta GA.
Find the tech sheet, usualy down in the pots drawer cavity or taped to the drawer itself.  It might have the magical fault code decoder.  If not, then this link might help with that:
http://fixitnow.com/2002/12/appliance-tip-of-day-range-clock-fault.htm
Then check out the sensor:
http://fixitnow.com/2003/02/appliance-tip-of-day-oven-temperature.htm
this one is fishy f1 for the most part means  sensor problem or stuck keypad problem most manufactures recommend removing the ribbon cable for 1min and reinstalling if you don`t have a ribbon cable i at this point would say look more closer at the oven sensor (model no# needed)
