Bryant split a/c leak
gabvoice2
Hi,
I have cool air. But my Bryant air handler model FA4ANF042 is gushing water out of a port just above the drainage pipe connection (see photo). The hole, where the water is coming from, seems to be threaded as to connect with a water hose or something. But there are two such holes positioned vertically (see blue plastic cap in picture). Note that my drainage system involves a 30' PVC pipe embedded in the garage's concrete floor
I suppose that one of these two holes is intended to connect a garden hose and apply water pressure to unclog the drainage system. But which one is it? The bottom hole is mostly obstructed by the PVC drain pipe. I could not attach a hose to it without cuting off the PVC drain connector. I don't want to put the whole unit out of commission for the sake of a water leak.
Otherwise what is the standard procedure to flush the drainage system?
Can you help?
  • Replies 9
THE  upper hole with the blue plug is only used if the air handler is installed upright  .   the other hole in the corner is for another drain pipe , some city codes require two drain pipes to be installed so if the first getys clogged the second one takes over ....... what you need to do is get a 3/4 pvc coulpling and with a lot of towls cut the pvc pipe in half a little way from the unit , you will have a gush if water A BUNCH OF IT !  thats what the towles are for ...... then you need to blow the lines with air , into the air handler and to the drain  , make sure you have flow before you glue the coulpling to the ends you cut to finish the job
Do you know where I can get a diagram of the Bryant air handler?
I need to get access to the condensation pan to drop anti-algae tablets in.
I don't have an air compressor to blow the pipes, but
the folks at Home Depot said that these tablets can clear the algae from the drain.
The top door of the handler comes off easily.
However, the bottom door, where the pan should be, seems to be glued with corking paste.
Should  I just throw the tablets through the open drain hole?
What do you think?
you where lied to , the tablets will only prevent the alge and thats not your problem anyway . the coil collects dirt and dust this washed away with the water that collects on the coil , then it goes down the drain and clogges it up ......DIRT IS YOUR PROBLEM  dont get "SOLD" .......  if you can get to where the drain line ends you might try blowing into it with your mouth ? .... but if it works you need to jump back quick or you will have a mouth of full of muddy water . and please dont buy any magic pills !
NO  dont mess with it . fix the problem you have , that is the clogged drain line .... cleaning the coil is tricky offten i need to drain the freon and disconect the coil to remove it to clean it , other times its just a matter of removeing the return duct , its real easy to mess things up and cost BIG $$$$$$ . just deal with the problem at hand , it should work out to be an easy fix
Old school techs use dry nitrogen to blow out the drain but you can use  a shop vac. Go outside to where the drain is and use a shop vac on it.. Get a rag and wrap around the pipe and let er suck all that mess out and YES non rinse foaming cooling coil cleaner will work and YES pan pills do work to kill odors in the house and keep the vents from smelling because of that lousy drain.
