Whirlpool LEB6300PW0 Dryer
36 replies to this topic
#1 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 01:37 AM
Dryer stopped working about 6 months ago.  Replaced the Push to Start switch as a local parts told me that it sounded like it had went.  Still will not work.  Discovered this Fourm from a friend.  Have checked everyting we can think of.  Jumpered the thermal switch to see if it had burned out with no luck.  How can I check ti see if the motor is getting power?
#2 NCSU_laundry_tech
NCSU_laundry_tech
    Senpai
  • Appliantologist
  • PipPipPipPip
  • 940 posts
Posted 25 October 2008 - 01:51 AM
thermal fuse and door switch are the first 2 suspects.
if those are ok you got to get a volt meter and the schematic to figure it out
in general if the motor is getting power you will get some type of noise
To alcohol! The cause of... and solution to... all of life's problems.
#3 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 01:58 AM
Jumpered the door switch and thermal fuse. Nada.  have a basic knowledge of the scamantic(?) but can't figure out which ones to test.  Don't need to get fried or burn something else out.:shock:
BTW, took this long to try to fix as we used solar power (line dried) but getting to cold out in NE Ohio now.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 25 October 2008 - 02:22 AM
Does it make any noise when you push the Start Button (Relay click) ?
Does the Drum Light work (if equipped) ?
Does the Timer Motor run (in the Timed Dry Mode) ?
Do you have a meter ?
Did you check this Thermal Fuse ?
#5 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 02:27 AM
will send pictures of wiring diagram if that would help.
#6 RegUS_PatOff
  • 33,588 posts
Posted 25 October 2008 - 02:29 AM
LEB6300PW0 Wiring Sheet
#7 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 02:33 AM
Yes to the first question
Yes to the second
No to the third, but can here some sound from timer.
Yes, I have a digital meter
No only checked the thermal fuse but jumpered it also as that is what we thought it was.  We turned on my meter displays 1 and when I put it on the fuse it shows between 0.2 and 0.3
#8 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 02:34 AM
thats what my wiring sheet shows.
#9 RegUS_PatOff
  • 33,588 posts
Posted 25 October 2008 - 02:49 AM
Check the voltage at the Motor:
Blue wire to White Wire
There should be 120v AC when the Start Button is held in.
#10 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 02:50 AM
Ok, will check it now.
#11 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 02:57 AM
No, no power to ot.  I hooked up my Voltage-Frequency meter to it and just recieved a flash on the 60hz but that was it.
#12 RegUS_PatOff
  • 33,588 posts
Posted 25 October 2008 - 03:00 AM
check the voltage from each of those Motor wires to chassis (ground)
check the voltage from each side of white Thermal Fuse to chassis (ground)
#13 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 03:07 AM
All the wires to the motor or just the two you mentioned before?
#14 RegUS_PatOff
  • 33,588 posts
you could check them all ...
#15 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 03:16 AM
Have power on both sides of the fuse.  On the motor I show power from the Blue wire and one of the Red wires.  There are two red wires on the harness.
#16 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
this is with the harness unplugged from the motor
#17 RegUS_PatOff
  • 33,588 posts
Posted 25 October 2008 - 03:22 AM
if you could check the voltages with the Harness plugged in...
do you have a white wire ?
Start Button held in and Dryer Knob set to DRY
#18 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 03:27 AM
ok will do and yes there is a white wire on the harness.
#19 Superdave58
Superdave58
    Ikkō-ikki
  • 21 posts
Posted 25 October 2008 - 03:31 AM
Have power to all but the wire going to gound and the black wire
#20 RegUS_PatOff
  • 33,588 posts
Posted 25 October 2008 - 03:40 AM
If there's power on the White wire to ground, then either the Timer contacts are bad or the Door Switch...
and if you can hear the Relay click when you push the Start Button, then the Door Switch is good.
Try it with the Wrinkle Guard Switch in both positions.
