Kenmore Dryer will not heat in drum
28 replies to this topic
#21 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 22 December 2005 - 01:24 PM
Cool, thanks for letting us know....;)
#22 Lurker_Debbie_*
Lurker_Debbie_*
  • Lurking at the Threshold
Posted 23 December 2005 - 06:45 PM
I have a similar problem - no hear, but I don't see a flame. would that be the ignitor that has gone bad.  Air comes out the vent but it is cold.
#23 Lurker_Debbie_*
Lurker_Debbie_*
Posted 23 December 2005 - 06:46 PM
Sorry that was no heat.
#24 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 23 December 2005 - 07:03 PM
What is the brand and model number of this dryer and does the igniter come on or not...
#25 Lurker_Debbie_*
Lurker_Debbie_*
Posted 23 December 2005 - 08:13 PM
It is a Kenmore  Gas dryer 110.76722691.  I'm not sure how to tell if the ignitor comes on.  When I look down towards to bottom with the top lifted there is no glow from a flame and I hear no clicks or noises except the start buttom engaging and the drum turning.
#26 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 24 December 2005 - 05:12 AM
Check the white plastic thermofuse on the back of your dryer, this will open if the air flow from the dryer is to high, could be your vent is blocked to the outside of this is open or your cycling thermostat next to it is defective..reference #39 on this breakdown...unplug the dryer, remove the back panel and it will be there on the vent housing on the left side...
#27 Lurker_Debbie_*
Lurker_Debbie_*
Posted 24 December 2005 - 11:32 AM
Thank you -- I was able to find the Thermal fuse today and replace it.  I tested the old one and it was open.  I also replaced the thermostat part 41. I read in one book that it could lead to blowing the fuse.  The old thermostat did have the same resistance as the old one, so it may not be bad at all.  The dryer now has heat, I wasn't looking forward to taking the clothes to the laundrymat to dry on Christmas Eve.
#28 Lurker_Debbie_*
Lurker_Debbie_*
Posted 24 December 2005 - 11:33 AM
Sorry the old thermostat had the same resistance as the new one. But I replaced it anyway.  Thank you once again.
#29 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 24 December 2005 - 04:08 PM
Thanks for letting us know, is best to replace both...save the old thermostat in case you might need it at a later time....;)
