Pat540i
Whirlpool Gas Dryer Fires only on some settings
5 posts in this topic
I had several posts some months ago and I thought I had the problem licked but apparently not.
My Whirlpool Gas Dryer (LGR6634DQ0) wasnt firing for the "timed" dry settings. Lots of clacking, couldnt keep the flame.   I redid the coils but same problem, check for loose connections , operating sensor too, did radiat sensor a few months before that.
Turns out, the clothes dry if I use the "very dry" settings on the dial with the unit checking for moisture.  Strangely enough, the thing fires and stays lit on this side of the dial but not the timed side.
Before I throw any more parts at this thing, do you think its the "dial" itself?
Thanks in advance folks.
Is it still not drying on the timed dry setting, too?
You got it.    It dries on the moisture sensitive settings but not on the timed settings.
How to make sure its not the timer works for many of the whirlpool dryers  .... I dont have a diagram Im going off memory   but im about 95 % sure on the wiring
Make sure that polarity is correct in the outlet.
Plug the dryer in and set the timer to timed dry  about 40 minutes.
Start your Dryer
SET your meter to read voltage
Take your black lead on your volt meter and stick it on a Nuetral wire at the outlet. (the one thats not a hot leg generally the fat side of a receptacle if its wired right)  DONT MOVE THIS LEAD LEAVE IT THERE
With the red lead on your meter check  the Black (marked on timer as BK) wire at the timer (should have 120v)
Next check the RED Lead coming out of the timer marked ® You should have 120v there
IF you lost power at any of those two points you have a bad timer.............
Let us know how ya make out .....
Start your Dryer
