Repair Forum Server
#1
Posted 19 November 2008 - 05:16 AM
#2
Posted 19 November 2008 - 06:25 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 19 November 2008 - 09:29 AM
#4
Posted 23 November 2008 - 08:39 AM
They've stopped replying to my "support" tickets.
Incompetent AND unresponsive. I rectum I'm just lucky thata way. :grunt:
#5
Posted 23 November 2008 - 08:58 AM
Now the quest for a reliable hosting solution for these forums begins anew. I'm wide open to suggestions!
Sorry for the problems and thanks for your patience and forbearance whilst I do some mud-wrastlin' with this server mess. :barbell:
#6
Posted 23 November 2008 - 10:41 AM
When I have a little more time, I will re-post about my dryer problem. I am getting it to work well enough that I got the wash done, but I do still have an issue that probably should get cleared up.
Thanks for making this forum available!
#7
Posted 23 November 2008 - 10:50 AM
Disconnect Dryer Vent.
Does it heat in the non-heat mode ? (Heater Element shorted to ground)
Check for good air-flow
Temperature should cycle somewhere between 135F & 160F with empty load, Timed Dry, High Heat. (meat thermometer)
If the temperature is higher, then it sounds like your Operating Thermostat is bad.
#8
Posted 23 November 2008 - 01:59 PM
Dryer runs with no heat on no heat setting. Air flow is good and temp is 145-150 on regular heat, timed dry, empty. If you have other thoughts, maybe post them on the other thread, in case someone else wants to follow along.
Thank you so much!!!
