Frigidaire Gas Dryer
7 replies to this topic
#1 Chef
Chef
  • 6 posts
Posted 25 July 2005 - 03:21 PM
I have a frigidaire Gas dryer that will not spin w/ more than  1/8 of a full load in it.. I have changed the belt twicw now and I just have no clue what else to do... any help would be greatly appreciated :D
Chef :yikes:
    Shōgun
  • Master Samurai Tech
  • 30,364 posts
Posted 25 July 2005 - 05:30 PM
When you say it won't spin, does that mean if you load it up, it stops spinning altogether (no motor sound)? Or does the motor keep running but the drum ain't tumblin'?
#3 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 26 July 2005 - 12:20 AM
Did you check to see if the idler pulley turned free?
Nick
#4 Chef
Chef
  • 6 posts
Posted 26 July 2005 - 05:32 AM
The motor runs, but if you put more than just a few articles of clothing in it, it is too heavy to continue to run. It heats and runs fine, but it tries to spin and then won't with more than a few clothes in it.
#5 Pegi
Pegi
  • 13,120 posts
Posted 26 July 2005 - 06:45 AM
***The motor runs, but if you put more than just a few articles of clothing in it, it is too heavy to continue to run. It heats and runs fine, but it tries to spin and then won't with more than a few clothes in it***
***it is too heavy to continue to run***   What stops running , the motor??? or does the drum stop turning and the motor keeps running.....??
#6 Chef
Chef
  • 6 posts
Posted 26 July 2005 - 10:46 AM
the motor continues to run.. but the drum stops turning.
#7 ApplianceTerminator
ApplianceTerminator
    Sōhei
  • 151 posts
Posted 26 July 2005 - 11:04 AM
change the belt and oil the idler ....
#8 nickfixit
nickfixit
  • 2,200 posts
Posted 26 July 2005 - 12:43 PM
How about this...
Get a new belt and a new idler pulley. Before you install them, clean the outside of the drum to remove any grease, oil, dirt, ect.. that may be on the drum. Then put some grease on the ball that the drum turns on (rear bearing).
This should get you back in the game.
