Whirlpool refrig buzzes for 10 sec, then rattles
5 replies to this topic
#1 je
je
    Ikkō-ikki
  • 32 posts
  • Flavorite Brew:Flying Monkeys Supercollider Double IPA
Posted 27 November 2008 - 12:13 PM
I have a Whirlpool side-by-side that's 12 years old. It operates perfectly fine, but for a couple of months it  has been making a loud buzzing noise from the compressor area (well almost everything is in that area) for exactly 10 seconds, and then about 30 seconds later a loud rattle that seems to be coming from the upper part of the unit.
Two years ago I asked here about my defrost drain clogging. I made a heater strap for it and all has been perfectly fine since (I didn't make the aluminum drain surround though, I hope it didn't melt any plastic). I can't get parts shipped to me since I don't live in the USA, but I'd still like to hear what might be the problem.
 The model  number is ED22PQXDW02
Check out some of these emoticons!
:fart: :huh::help::doublefinger::moondance::knifehead::burning::runover::blech:
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 November 2008 - 12:56 PM
Depending on model number...
it could be the Compressor Start Relay / Overload...
have you tried Sears Canada Parts
#3 je
je
    Ikkō-ikki
  • 32 posts
Posted 27 November 2008 - 01:14 PM
What would be the rattle? It doesn't seem to be from the same area.
The model is ED22PQXDW02
The refrigerator works normally, except for these two noises. I should also add that I don't hear the compressor or fan running (maybe I shouldn't hear them) at any time this is happening, but the refrigerator keeps a constant temperature.
#4 grey shrek
grey shrek
    Kohai
  • 412 posts
Posted 27 November 2008 - 04:30 PM
Sounds silly , but do you have an ice maker not hooked up to water but not shut off.  Back in my sears days we had a whiz kid order every moving part on a fridge. Another tech went and lifted the arm on the ice maker = noise left.
#5 je
je
    Ikkō-ikki
  • 32 posts
Posted 29 November 2008 - 03:26 AM
That arm - is it the thin wire on/off one?:yikes:
I did that and will monitor. So it won't sense that the ice level is low, open the water valve, then not do something up in the ice maker area?
I hope so. If it is I will owe you a .:pint:
#6 grey shrek
grey shrek
    Kohai
  • 412 posts
Posted 29 November 2008 - 02:21 PM
That's the one. :D
