jued0001
GE Triton Quiet Power III Dishwasher no longer turns on
7 posts in this topic
Model: GSD5330D02WW
Serial (if it matters): ZZ716075B
This machine has been fine until now. For normal use, you put in the dishwashing powder, close the cover for it, cloe the door and latch it and it will power up. Now I get nothing. It appears to be on the same fuse as the rest of the kitchen, and everything else has power.
I figure the failure is in one of many spots:
1-at the detergent cover
2-at the door latch
If I can get away without calling a repairman, life would be good. Any suggestions (and thx in advance)?
You need to see if you have voltage at the dishwasher, if there is 120 volts to the unit I would check the door latch switch next.  Do not see how the soap cup would have any bearing on this problem tho.
If memory serves correctly (it may not...), if the soap cup wasn't properly closed, the unit wouldn't power up even if the door was latched (when it was working).
So, do I need to remove the lower most panel on the front to get at what I need to (to check the power)?
Cool, learn something new every day.  My W.P Gold Tall Tub could not care less if the cup is closed, I just throw the tablets into the bottom of the tub. And the G.E. units we have worked on have not seen this on either, but yours may be different, you will need to get your wiring diagram from out of the bottom right under the unit after you remove the toe panel to see if this det. cup is wired into the controls, would be the first one I had seen so please let me know if this is so. You will be accessing the door latch after taking the inside of the door apart, and to access the wires to the unit will need to remove the toe panel and see if there is 120 volts to the unit where it ties into the dishwasher.
Not sure when if I'll get the time to work on it before the weekend, but I will post to let you know what I find.
Sorry it took so long to update this, but it didn't get fixed until yesterday.
The problem is that whoever wired my kitchen did a very poor job of doing so. One of the 'protected' outlets (can't remember the name for it, CFI or something) had popped and that cut power to the washer and other outlets in the wall. Once it was reset, power was restored.
And I also checked the detergent door thing - you were right, it worked whether it was closed or not. Not sure what I was smoking to think otherwise.
D'OH! :headbang:
