srdu7993
GE dryer # DDE7200SBLWW
6 posts in this topic
With the switch at high heat it climbs to 140 then retreats to 120.  Did not remove the thermostats but ohmed them and they seemed together.  Cleaned the heat selector switch too.  No difference.  Would I obtain 120 degrees if the element was broken?
Steve
The thermostats are rated like 140-20 or 150-30, this means the element(s) shut off at 140* and come back on at 120*,,or shut off at 150* and come back on at 120*.  What is the rating on your thermostat???  This dryer should have 2 elements, if one was  broken not sure you would heat to 140*.  These dryers usually had a 150-155* cycling thermostat under the lint filter for high heat and around 135* for low heat. You might want to see what is stamped on the metal on these thermostats.  If the high heat is rated at around 140-20, this sounds like it is running ok.  But need to see what is on these first.
Thanks I'll take a look at what they are rated.  The three thermostats I can find are located under the lid near the back up top.  Are there more under the lint trap?
Steve
Reference #'s 274 and 275 are your cycling thermostats, behind the front of the dryer, the ones on the element are hi-limit safetys and would be rated much higher, around 300* or so I believe, but could be going bad causing your dryer to short cycle.
Leadimage.asp?productTypeID=0151200&brandID=0432&modelDesc=DRYER&modelNumber=DDE7200SBLWW&documentID=E2138129&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET&titleID=00003&
Thanks again.  I'll check those out too.  Is there any easy way to get to them?
Steve
Remove the front of the dryer, they are behind that panel.
