commurcial crystal tips ice system
4 replies to this topic
#1 librassur
librassur
  • 2 posts
Posted 16 April 2005 - 07:42 AM
hi,i have a commurcial crystal tips ice system.i have search the internet for crystal tips ice system but this company has no website so i'm real stuck here.
here the problem.earlier sombody already worked on the system but i think something went wrong with wiring the system.(now when i'm calling him he dos not pick up the phone)the system is making ice and all but when the ice reaches its original ice size the compressor suppose to shut off and the two fans should keep spinnin,but the oppisite is happining.the compresser stays on and the two fans stops spinnin.i have made some pitures of the wiring so u cant see what i'm talking about.what i need is a full wirring diagram of this system so i can rewire the ice system.i already have tried to replace the thermostat but no luck.same thing is happening.i think that  a wire is not in the right place in defrost relay.
i hope somebody can help me solv this problem
manufacturer:crystal tips
serial(143742-11A)
model(1202-CAS-261)
#2 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 17 April 2005 - 07:22 AM
A simple solution is to rectify the wiring so that the thermostat is used to control the compressor and not the fans.:cool:
The Seven
#3 librassur
librassur
  • 2 posts
Posted 17 April 2005 - 07:31 AM
thx for the reply but i was wrong about the fans.the fans should stop spinnin and the compressor stays on but at that moment the compressor is losing hot gas for the ice to get lose and fall in to the ice bin.the only thing i need here is a wiring diagram to see how the thermostat is hooked on the defrost reley i don't think the wiring is in order.i'm 99% sure that cables has to be switch on the defrost thermostat .
the problem is wich one and where dos it belong
#4 Budget Appliance Repair
  • 3,999 posts
Posted 18 April 2005 - 04:36 AM
WOW!!! What a wiring nightmare, It looks like someone has really done a job on that unit!!!!!!
William Burk (Willie)
Eureka, CA 95501
Eureka, CA 95501
  • 24,321 posts
Posted 18 April 2005 - 04:52 AM
I hate when I get jobs like that.  :knifehead:
