lblatter
Frigidaire Front Load washer
3 posts in this topic
I have this machine and the water will NOT drain.  I have taken the hose out of the pipe (into my drain system) and laid it flat to get all the water drained out.  The washer then will go through all of its cycles - however unless the hose is lying FLAT on the ground (not into the drainage pipe), the water will not drain from the washer.
Before I pay a million dollars for a repair person - any suggestions of what else to try?
Quite possibly an obstructed of failed pump. Our illustrious leader has some assistance on checking this right here.
remove the lower front access panel,and locate the pump at the front r.h. side of the machine. remove the hoses from the pump and remove the coins etc. that may have accumulated there. worst case scenario is that you have a bad pump/motor which you can order here through this web site for much less than the million dollars you would pay for one of us to do it.
