aguyintx66
whirlpool lsr8233eq0
2 posts in this topic
I took the pump and motor off and found a bad coupler. With the motor off the agitator still will not turn. I do not want to replace the coupler if something else is still wrong. The shaft on the gear  box does turn. The original problem is it will not agitate or spin. It fills and drains.
dont worry, put it back together and it should work
