maytag msd2756dew gone hot
9 replies to this topic
#1 dynomit72
dynomit72
  • 7 posts
Posted 05 January 2009 - 06:29 AM
Ok im new here so bare with since I just got a $1300 dollar repair for my car I decided to attempt frig repair myself so here is whats happening evaporator is freezing in freezer compartment manual defrost will make frig work for about one week before same thing happen again I think problem started when i started to discover  leaking from under frig i think it was coming from under freezer side door since there is alway a quarter inch slab of ice on the floor on that side.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 January 2009 - 06:42 AM
sounds like the infamous bad ADC Board
I have the MSD2756AEW, and have had the same problem ..
see this thread from 2005
http://applianceguru.com/view_topic.php?id=119  Posted Image
and I joined on page 2
Maytag Refrigeration Service Manual
#3 dynomit72
dynomit72
  • 7 posts
Posted 05 January 2009 - 07:48 AM
ok thanks where might that adc board be located.
#4 GLC
GLC
    Kohai
  • 301 posts
Posted 05 January 2009 - 08:03 AM
Hi ya,
Number 13 is the ADC board. It is loacted in the beer section on the rear top right corner.  Look for a few screws to remove, then the plastic housing assembly must come down.  That comes down by placing a finger above the left rear, and one above on the right rear.  Then pulling down and forward at the same time carefully not to break the tabs that you are sliding it from.
Page 2-15 of the manul posted above by RegUS
Unless specifically asked otherwise, remember to test with the unit unplugged, or breaker off.
CLICK HERE TO BUY PARTS
Appliance Repair In Maryland http://serviceeveryday.com
#5 dynomit72
dynomit72
  • 7 posts
Posted 05 January 2009 - 08:17 AM
ok thank in going in.
#6 dynomit72
dynomit72
  • 7 posts
Posted 05 January 2009 - 08:27 AM
ok ive got it in hand sounds like it rattles a little can I buy this local u think?
#7 RegUS_PatOff
  • 33,588 posts
Posted 05 January 2009 - 08:44 AM
Whirlpool part #61005988
Any part ordered from RepairClinic can be returned in original condition
within 30 for a refund (less shipping)
Purchase from RepairClinic helps support this site or The Beer Fund
http://www.repaircli...?R=154&N=948430
#8 Budget Appliance Repair
  • 4,966 posts
Posted 05 January 2009 - 09:37 PM
I think you have a blocked defrost drain.  The slab of ice on floor of freezer is from the defrost working and melting the water and making a glacier because the water can no longer go down the drain tube into drain pan under refrig.  Every time it goes into defrost fresh water is flowed over the glacier and out front of freezer door and drips down between kickplate then out onto floor making it look like it's leaking from under the freezer area somewhere.
This glacier could very well be built up high enough to block the air return vents at the bottom.
When you say the evaporator is freezing, do you have lots, (all fins plugged with crystal ice), or just a nice thin frost over all coils except at bottom the clear glacier ice?
William Burk (Willie)
Eureka, CA 95501
#9 dynomit72
dynomit72
  • 7 posts
Posted 05 January 2009 - 11:43 PM
completely iced over thick ice.
#10 Budget Appliance Repair
  • 4,966 posts
Posted 06 January 2009 - 10:29 PM
When you say thick ice, (do you mean clear and solid?) or (frosty?).
How about some pictures, that would tell us a lot.
You need to melt all the ice and make sure the drain is clear all the way to the pan under the refrig, (make sure all air passages are free of any ice before turning back on).
If you have solid ice, you don't have a defrost problem.  The evaporator is defrosting ok but water has no where to go so it makes the glacier and eventually plugs off air return ducts.
Eureka, CA 95501
