Kenmore water dispenser won't dispense!
  • This topic is locked This topic is locked
15 replies to this topic
#1 Guest_Brad_*
Guest_Brad_*
  • Lurking at the Threshold
Posted 16 April 2005 - 12:14 PM
Kenmore model 106.57285791 Refrigerator water dispenser doesn't work - push lever, nothing. I replaced the twin solenoid, same thing. Ice machine works fine. What do I do next?
#2 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 16 April 2005 - 12:25 PM
Sometimes when it does that you need to change this thing
#3 Guest_Brad_*
Guest_Brad_*
Posted 18 April 2005 - 11:54 AM
You don't think it could be in the electronics at all?
#4 Ron
Ron
    Kohai
  • 368 posts
Posted 18 April 2005 - 12:25 PM
Brad,  it's possible the problem may be in the selection switch but check out a couple things first.   First make sure that the desp. lever is making the switch.  This switch is on the housing that the Samari sent you a picture of.  Next,  your model has a water reservoir on the refrigerated side in back,   This could be frozen near the outlet of the reservoir.  It has two lines going to it,  one going in and one going out to the water desp.  Take a hair dryer and go over it lightley so you don't burn it,  keep moving the thing.   Then check the desp. again...see if it starts spitting water....Ron
#5 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 18 April 2005 - 02:49 PM
   Usually not "electronics".  Put your ear to the fridge.  Make sure you hear the little switch in the dispenser recess CLICK when you press the cradle to get water.  Do you hear a hum coming from the solenoid?  Could also be the door switch.  Do you own a meter?  Could also be frozen someplace like Ron says.
    To get the cover off so you can get at the part I mentioned you'll need a large flat screwdriver.  Get on your knees and look up at the bottom of the recess area.  You'll see two places where you can put the screwdriver blade.  Don't scratch your freezer door.  Give the screwdriver a firm turn.  You will hear a horrible loud crack.  Do it to both side then pull the bottom out and lift up.  Piece of cake after that.
#6 Guest_Brad_*
Guest_Brad_*
Posted 23 April 2005 - 07:02 AM
Thanks both Ron and Jedi! Replaced the control bracket and all is well. I probably didn't need the solenoid at all - oh well. And Ron thanks for the hint on removing dispenser cover. I would have had to buy one of those after I roughed it off my way.
#7 Guest_Brad_*
Guest_Brad_*
Posted 23 April 2005 - 09:40 AM
Oops!  I meant thanks to Jedi for the tip about the dispenser cover!  :notworthy:
#8 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 23 April 2005 - 09:53 AM
You're welcome Brad.  Glad I could help.  Couldn't have done it without the Samurai.
May the force be with you.
#9 Guest_Mr. Fixit Dad_*
Posted 04 March 2006 - 07:18 AM
The water dispenser on our Kenmore model 106 has quit working. Only a couple ounces of water come out and then it shuts off. What do I need to check first?
#10 Pegi
Pegi
  • 13,120 posts
Posted 04 March 2006 - 08:06 AM
I would start by seeing if the fill valve on the disp side is going bad, not holding open when power is applied to the coil...
#11 jmundus
jmundus
  • 2 posts
Posted 05 March 2006 - 02:19 PM
Kenmore model 106.9555712 won't dispense water.  The ice maker works fine.  In addition, there is water flow from the holding tank through the tube to at least the connector at the bottom of the door.  When I take the tubing apart at the connector at the bottom of the door and push in the dispenser water shoots out, but when I reconnect no water comes out of the dispenser.  It seems there may be some blockage, but I'm not sure how to go about "unblocking: it.  Any help would be appreciated.
#12 bigger hammer
bigger hammer
    Kohai
  • 288 posts
Posted 06 March 2006 - 10:33 PM
jmundus
most likely the water line within the freezer door is frozen.
unfortunatelly non serviceable since the door and liner are glued together and the inside filled with that expanding foam insulation.
i do subcontractor work for sears and  *their*  procedure is to install temp recorders in fridge and freezer for 24 hrs to determine if its a temp regulation problem....if so then the thermostat gets replaced
if not then the entire freezer door gets replaced. so unless its under warranty this may cost abit.(500-600 for regular door or 700-800 for S/S)
 the door comes prefabed with all dispensor hardware, water line etc.... the gasket, handle, and shelf bins/rails get swapped over.
so you may wanna try turning the fridge down one or two increments and wait 24-48 hrs or even replace the thermostat first..... as far as thawing that line out maybe try turning of fridge and leave freezer door open for 15-20 mins
UNLESS......if you have one of the earlier models then the liner is screwed on to the door which now makes the water line accessible. pry the door seal back and check to see if there are screws (if there are ....... did i made you poop your pants talking about replacing the entire door  lol:P)
Before you start.....how much is it going to cost and how long is it going to take?
#13 jmundus
jmundus
  • 2 posts
Posted 08 March 2006 - 06:16 AM
big hammer,
Thanks for the help!!  The water is now flowing again.:)
#14 bigger hammer
bigger hammer
    Kohai
  • 288 posts
Posted 08 March 2006 - 08:13 PM
quite welcome :dude:
#15 Guest_wyverta _*
Guest_wyverta _*
Posted 16 October 2007 - 08:58 AM
kenmore 70 series,model 20712990, Washer is overflowing with water can't stop water from overflowing. what do i do next?
#16 Pegi
Pegi
  • 13,120 posts
Posted 16 October 2007 - 09:05 AM
Please register then re-post this in the washer repair forum, meanwhile turn the water off to the washer...closing this thread now since it is unsecured...;)
