Sub Zero 550 condenser fan stalling
6 replies to this topic
#1 jnooley
jnooley
  • 7 posts
Posted 19 January 2009 - 12:50 PM
Hello Samurai,
  I've got a problem with my Sub Zero 550 built-in fridge. The other day I walked by it and noticed it was making a noise I hadn't heard before. Upon pulling off the top grate, I could tell the noise was coming from the condenser behind the grate on the top right of the fridge. The sound is like a low buzzing noise. I also noticed that it seemed a bit hotter up there than I remember when I last vacuumed up there. So, I took a look at the condenser fan(between compressors and condenser) and it was not running. Thinking maybe it was possibly stuck due to some dusty buildup, I gave the fan a little help and gave it a spin. It immediately starting spinning at the expected speed. The fridge then started sounding like it should and about an hour later I checked the top and it was much cooler with the fan still running. The problem is that every morning when I come downstairs, the condenser fan is not running again and I have to give it a little help to start moving. Sure enough, it starts going and everything seems to work for the rest of the day just fine. My question is, should I assume that my condenser fan is failing or might there be some other underlying problem that is causing the fan stall? Any help is much appreciated. Thanks.
#2 Trying to help
Trying to help
  • 2,464 posts
Posted 19 January 2009 - 02:14 PM
If there is power at the fan, and it is not turning, she's bad.  The fact that it takes off running when you flick it, indicates you have voltage there.  Get yourself a fan motor before it takes out all your food or compressor.
#3 jnooley
jnooley
  • 7 posts
Posted 19 January 2009 - 05:39 PM
Much appreciated advice. I couldn't seem to find that part at repairclinic.com. Is there an online parts store that you would recommend for that part? Thanks.
#4 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 19 January 2009 - 05:43 PM
You wanting this??
http://www.repaircli...6&PartID=753856
#5 jnooley
jnooley
  • 7 posts
Posted 20 January 2009 - 03:40 AM
That's the part. Thanks for the help finding it. I overlooked that first section labeled "Belt / Motor / Pulley / Motor Coupling" :).  I'll be sure to post when I get a chance to replace it. Thanks again.
#6 jnooley
jnooley
  • 7 posts
Posted 24 January 2009 - 05:16 AM
Got the part, installed it and all is well. The fan is cranking now! You guys are great. Sending $5 more for the beer fund. Wish I could send more but things are pretty tight right now. Thanks a ton!
#7 certified tech group 51
  • 2,677 posts
Posted 24 January 2009 - 06:07 AM
I love a story with a happy ending...... thanks for keeping us posted on results of your repair.........:party:
