maytag stack washer
1 reply to this topic
#1 torchkeeper
torchkeeper
    Ikkō-ikki
  • 40 posts
  • Flavorite Brew:bloody decks/ screamin reels
Posted 16 April 2005 - 01:00 PM
my washer continues to aggitate the load " and me" even after it counts down into the rinse cycle. if i push off button, lights go out but still continues to aggitate. will keep going till end of time ortill i open the door. any ideas? for some reason i think it has something to do with contacts in the switch activated by safety latch!!
this happened a couple months back and hasn`t come back till now.
thanks, for the help
  • 24,207 posts
Posted 17 April 2005 - 01:52 AM
This is most likely a flakey control board
You should use the wiring diagram, located inside the control panel,  and your trusty multimeter to confirm.  For this washer/dryer set, I highly recommend the repair manual set from Maytag.  IT'll have all the disassemble, diagnostic, and repair procedures you needs, including the wiring diagram and schematic.
