Whirlpool Direct-Drive Still no want to Spin
5 replies to this topic
#1 Marksan
Marksan
  • 3 posts
Posted 30 July 2005 - 08:16 AM
I am working on my dishonorable Whirlpool LSR8233EQ1.  The original symptoms were fill - fine, atitate - fine, drain - fine, spin - loud noises and no spin.  I took it apart, and found a broken brake cam.  I replaced this along with the clutch since they all came in the same kit.
I put it back together, and now it spins, but very slowly, and still makes the loud noise.  What is my next step?
#2 nickfixit
nickfixit
  • 1,962 posts
Posted 30 July 2005 - 08:21 AM
Make sure you don't have something stuck between the spin basket and the outer tub. (like a sock)
#3 Marksan
Marksan
  • 3 posts
Posted 30 July 2005 - 08:35 AM
I believe I need to remove the spanner nut to get the spin basket out.  Is that correct?  If so, is there a way to remove the spanner nut with common tools, or do I have to get a special wrench?
#4 Marksan
Marksan
  • 3 posts
Posted 30 July 2005 - 08:42 AM
I took the plastic ring off the top of the tub, and looked down around the sides of the spin basket.  I see nothing in there.  Also, the spin basket will turn by hand.
#5 Pegi
Pegi
  • 13,120 posts
Can use a big screwdriver or chissel and hammer and tap it to the left.
#6 Budget Appliance Repair
  • 3,995 posts
Posted 30 July 2005 - 11:26 PM
If the spin basket turns easily by hand then you most likely have a broken drive block also. Take the agitator out and look at the spanner nut, does the spin tube stick out above the top of the spanner nut about 1/2" to 1", if YES, then replace the drive block.
If the drive block is stripped, make sure to carefully bend all four corners of the tabs that stick up back out to their correct position. A tappered chisel tapped gently between agitator shaft and spin tub tabs will bring them back into correct position so as not to strip out the new drive block.
William Burk (Willie)
Eureka, CA 95501
