Kenmore Microwave 721.8915081
2 replies to this topic
#1 Breez360
Breez360
  • 4 posts
Posted 08 February 2009 - 06:28 AM
I was replacing the bulb and didnt make sure the power was off. It sparked and has been dead since. It cooks fine and the light inside works. I checked for fuses behind the control panel and only found one. It was not blown. Is there another fuse somewhere I should check?
The only stupid question is one that isnt asked.
#2 RegUS_PatOff
  • 30,262 posts
Posted 08 February 2009 - 07:06 AM
It may have taken out some parts on the Controller Board.
Look on both sides for burned spots.
Sears lists the board for $ 85   :(
#3 Breez360
Breez360
  • 4 posts
Posted 08 February 2009 - 08:51 AM
Absolutely awesome help.
I pulled the board out and found a burned trace on the back side. I was able to repair the trace by soldering in a short jumper to replace the bad spot and upon re-assembly the lights and fan work great.
Very much appreciated.
