waltbush
Hotpoint Large Capacity Dryer won't heat.
5 posts in this topic
Big problem. No, I could live without the dryer heating, but my wife can't. That's my problem. The Hotpoint dryer's problem is there is no heat being generated although the blower is working well. I guess I should check the thermal fuse (if there is one), and look to see if anything is happening with the ignition system (nothing looking from the back end). However, how do I remove the panels to look inside?
Walt Bush
OK, I removed the top and front panels. I found some lint, about a fist full in the air channel just in front of the blower, removed it and put everything back. No luck. It still won't heat. I did look for a thermal fuse but can't see very well with the drum in place. Also, I can't see whether the igniter is working very well without removing the drum. Looking through the back access panel and with the lights out,I could see no illumination from the igniter (drum not removed). I don't know if this is good enough to see the igniter in action. Is my next step to remove the drum or have I seen enough?
With appreciation for your help,
Walt
Hello, my fist-full of friend. I read where you had stumbled upon one of the many pearls of wisdom cast before the heaving masses by our exalted and vain-glorious leader, Samurai Appliance Repair Man. Perhaps I could help you to further help yourself by directing you to other pearls from the Samurai. Would you like that? Very well.
Begin with the general dryer diagnostic page. After carefully considering the wisdom contained therein, proceed to the gas dryer diagnostic page. To help you test the various parts, I refer you to the electrical measurement instruction page.
Dear Ayatollah.
I bow to your superior knowledge and shall do as you command. I doubt that I would ever be able to reach the exalted heights of appliance fixology that you have attained but I shall forever remain just a simple servant in your service and will, to the end of my days, extol your virtue of compassion for those of us of lesser abilities.
With palms together,
Walt
