breischaft
GE Profile Icemaker Problem: Stopped Making Ice.
2 posts in this topic
Everything was fine until today unit stops making ice.  Wife cleans out tray and makes sure no buildup of ice.  Machine makes 1/2 dozen cubes then nothing.  Please help.
This could be a broken ice maker, fill tube clogged with ice or the fill valve to the ice maker went ka-poot.  Check the thru tube first to see if it is blocked then suspect the fill valve unless this has an IM6 ice maker, the one with the paddle instead of the wire on/off arm, the IM6 has known issues with the circuit board going south.
