whitrock1
Another Kenmore won't spin
9 posts in this topic
I have a direct drive kenmore. It will agitate, rinse... do everything, but will not spin. I took the transmission out and found the brake cam lever small tab broken. I replaced it along with the clutch assy. same problem. I can hear the motor running during the spin cycle. The drum will turn by hand but is very stiff, but i don't have anything to compare it to. I am not getting any strange noises. I just hear the motor running. Could this be a transmission problem??:D Thanks
Sounds like a tranny problem which has a 5 year warranty, how old is this unit.
You can test the machine with the cabinet off, just make something to jumper the lid switch. Then run the machine and see if the clutch bell is spinning in the spin cycle.
If this was mine i would do the following...
1)Remove the spin basket and check for any foriegn objects
2)Inspect the drive block for wear. The top sould fit over the two raised spots on the spin tube.
3)Remove the transmission, and inspect the clutch pads
4)Remove the Spin tube(basketdrive)
5)Put a thin coat of grease or turbine oil on the spin tube.
6)Replace the clutch, or sand the pads and clean the inside of the bell
7)Put it back together and try it
If it still don't spin, then you know you need a gearcase
It's at least 10 yrs old. I am going to run it tomorrow without the cabinet & watch the clutch. No spin . Then it's the tranny??
I checked the clutch bell and it started to spin then stopped. Motor was still running. This is a trans. problem. Right?? If so can you rebuild the tranny or just replace it?
I've never rebuilt one. I have used rebuilt gearcases, And they usually make a lot of noise, and fail real quick. I only use new gearcases now, I hate doing things twice.
Check or hosts price on a gearcase.
I would check to make sure to see if the drive block is not cracked. I have replaced the block that the drum sits on a few times.
Thanks for the trouble shooting. The tranny fixed the no spin problem. But now I have a bad vibration. I checked it and it is level. Could it be the white slide plate? I can't really tell if it is out of line or not.
Yes, this could be out of place, pull the case and make sure the 3 white tabs on the triangle plate are inside of the 3 brown tabs on the base.  Also one or more of the brown tabs could have gotten damaged. Carefully lift the corners of the plate to check on the brown tabs.  Also check to see if the lock nut is tight if you pulled the spin basket and the basket is wobbling, altho this would not have had to been removed just to replace the tranny.
