Really could use some masterful Samurai help on that Amana
2 replies to this topic
#1 mdadian
mdadian
  • 19 posts
  • Flavorite Brew:Killians
Posted 18 March 2009 - 05:20 PM
I pulled the machine away from the wall to repair a problem with the stand pipe and then pushed the machine back into place.  I failed to level the machine before running it again, and now it makes a horrid screaching noise in all phases of opperation.
My only thought is that it sounds like a fan belt on a car that is slipping or the sound of a power steering system run dry.  The belt has thrown flecks in all directions, but it doesn't SEEM too bad.
Help would be greatly appreciated.
Would belt dressing help?
Thanx,
Mark
He is Risen!
    Shōgun
  • Master Samurai Tech
  • 29,063 posts
Posted 19 March 2009 - 03:30 AM
Are the flecks wet or oily? Could be a leaking tub seal or simply a worn belt that needs replacing. Post a picture if you can.
#3 mdadian
mdadian
  • 19 posts
Posted 19 March 2009 - 03:37 PM
Thank you sensai.  Will try to get one on tomorrow.
G-hopper.
He is Risen!
