  • Announcements
Sign in to follow this
Followers 0
Guest BHIRepairGuy
Jenn air S105 Oven Problem
2 posts in this topic
I've got an older Jenn air range that the oven cuts off above 325 degrees. Doesnt have a tech sheet. Swapped the thermostat control with a known good one, same deal. If you turn the oven temp control past 400 the lock light comes on, then goes off at 500-525 degrees. Anyone got a tech sheet for this puppy or any ideas?
I will check my old files... I had books on these old Jenn Aires a long time ago...
I will see if I can find them...
Followers 0
