slow agitator
3 replies to this topic
#1 Guest_swillyone_*
Guest_swillyone_*
  • Lurking at the Threshold
Posted 31 March 2005 - 06:52 AM
Great website before I begin!!!!  Ok, my agitator spins just fine during the spin cycle but during the wash cycle it moves slow as molasses :shock:.  Should I try to change the belts to fix it or does it sound like another problem is 'a brewing?  Thanks
Swilly
  • 24,207 posts
Posted 31 March 2005 - 07:25 AM
The range of possibilities is as wide, tall, and high-- all depends on the brand and model number of your washer.
#3 Guest_Model number_*
Posted 31 March 2005 - 08:01 AM
That makes sense.  Does this help? Maytag model number:LAT9406AAE
  • 24,207 posts
Posted 31 March 2005 - 09:01 AM
Oh yeah.  Might be a worn belt set:  pump belt and drive belt.  If the sidewalls of either are smooth or glazed, replace both as a set.
The motor mount could be gunked up and binding or have a broken spring.
Remove that front panel and have a look.
