Dryer Works Sporadically...suspect motor
1 reply to this topic
#1 mjeep01
mjeep01
  • 1 posts
Posted 17 April 2005 - 02:57 AM
Kenmore. 110.96590140.
Hi, my dryer was working great until recently. I noticed a strange buzz and then the dryer stopped working. I cleaned the lint tray and removed most of the clothes from the dryer. It worked for about 5 min. & then shut off. The timer was still on and after about 5 min., the dryer kicked on again automatically.
Eventually, the dryer stopped working. I was able to get to the motor. I removed all lint inside the cabinet, around the motor, etc... I also removed the belt from the Idler Bracket. I then simulated tension on the Idler Bracket the belt would do by raising the Idler Bracket to flip the switch and the motor started. After about 10 seconds, I released the Idler Bracket and the motor stopped. Again, I simulated tension the belt would have on the Idler Bracket but this time the motor froze. I heard the motor humming like it wanted to turn but couldn't. It's as if something was jammed in the motor. After a few repeated incidents of attempting to get turn the motor over, the motor didn't even hum, just silence.
After waiting a bit, I could repeat the entire cycle again (motor runs, motor locks, motor silence). Does this sound like a motor problem to you? There is a pluggable motor switch that I suspect could also be the problem but I really think it's the motor. Thanks!
#2 Budget Appliance Repair
  • 3,999 posts
Posted 17 April 2005 - 03:22 AM
Diffinitely sounds like bad motor bearings freezing up after running and heating motor up from to much drag in bearings.
Get your new motor: CLICK HERE
William Burk (Willie)
Eureka, CA 95501
Eureka, CA 95501
