neehowhenhow
LG WM1814CW
57 posts in this topic
Greetings!
I am in the hate part of my love/hate relationship with my LG washer.  I have followed so many instructions, flooded the basement, cleaned filters, even sang it a song to soothe its worried self, and still I cannot stop it from yelling at me "OE" clean the filter, unbend the hose!
Sheesh, what must I do know? Genuflect? I will if it will get my laundry clean!
Please oh wise and all knowing Samurai (and gang) Please enlighten me on how to trouble shoot (or shoot) this beast!
With humbled thanks
Amyjean
OE Drain Error:   • Not fully drained within 10 minutes.
Does the washer drain out fully ?
Did you clean out the Filter behind that little door on the lower left front of the machine ?
was it clogged ?
I did clean out the filter on the bottom front, plus looked inside to see if there was anything lodged in there. It was clean.
I then looked at the grey drain hose in back, and sure enough, as I ran a short cycle- it sat showing 15 minutes- forever- then the hose moved- but no water draining at all. I could hear it working to drain- but no draining.
It could be a bad Pump ...  or still clogged somewhere...
try taking the Hose off... (may need some towels ...)
WM1814 Service Manual
OKay- here is where I should stop. If I attempt any type of removal of crutial operating parts,  I feel we will be buying a new machine. Me and machinery =bad combination.
Seriously,  I blew out the power to our neighborhood thinking a range repair component was "plug and play"...the arc was pretty though.
I think my dear Husband can do this task.:)
Thank you for your help! I'll let you know what happened after he wrenches on it.
$450.00 later...
the pump is shot. 3 yr old machine and it has burned out.
Why? Because the drain hose in back was pushed all the way down to the bottom of the drain pipe, which restricted adquate air flow for proper drainage.
Its Thursday- repair should be done Wednesday...
I've got 4 kids...
and no washer
:shock:
[user=49197]neehowhenhow[/user] wrote:
$450.00 later...
I've got 4 kids...
and no washer
:shock:
disturbed.gif i need to raise my prices.....
oh my- please dont say that!
I hope I wasn't "Hosed" :D
so- onto my soapbox.
I am reading that more and more people are experiencing problems with this particular company product.
http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
The technician said that the INSTALLERS caused the problem and he sees this burning out of motors a lot.
I just wrote a scathing letter to LG and now off to Home Depot.
hell hath no fury! And I hath no washer!!!!!!!!!!!!!!
It's not just LG (if you believe any of those complaints from that website)
here's the link for Whirlpool
http://www.consumeraffairs.com/homeowners/whirlpool_washing_machine.html
Sears Kenmore
http://www.consumeraffairs.com/homeowners/sears_washers.html
Frigidaire
http://www.consumeraffairs.com/homeowners/frigidaire.html
LG Pump $ 52
click on picture
LG WM1814 Service Manual
I just cant see the drain hose too far down into the drain causing the pump to fail. Usually the pump fails from coins, hairclips, toothpicks, etc. getting stuck and stripping out the impellor. I like LG, their parts are usually about half the cost of other manufacturers making them more affordable to repair.....and yes you are getting hosed.
Looks like I need to make a call in the am.
thank guys
well,
I stopped the process with the repair company and I ordered the part myself. I also learned directly from LG they do NOT recommend the company I went with.
I wonder if I can install it myself or should I get some help?
any thoughts?
any thoughts?
Piece of pie, Neehow!  Reg hooked you up with the manual, just read the section about replacing the pump. Purdy pitchers, too!  The biggest problem you may have is dealing with the hose clamps and some residual water that'll dribble outta the drum.  But these truly are minor things.  You can do dis!  If you can, it'd be way cool if you could take some of your own purdy pitchers of your handiwork and post 'em here so we can celebrate your victory with you.
Many thanks oh gracious and all knowing Samurai!
The pliers used are just ordinary "Channellock" type pliers, (slip-joint, pump pliers, etc.). They are called by many different names. You can also use Vise-Grips (locking pliers) which I find much easier to use on those type of clamps as you can just set them and they keep the clamp open so you can wrestle the hoses back on.
However, you needn't remove the clamps on your LG, the drain pump just unscrews from it's housing with three little screws. You can access it by pulling the machine out and tilting it back at about 45° and reaching in from the bottom. Very easy job. Just unplug it first!
PS: $450??????? I need to triple my prices again.
450 for a pump??? we charge 80 for the pump and 158 for trip and labor..... lets double our prices!
well,
Good work! Congratulations on saving yourself some serious coinage and especially for not feeding that ripoff shop.
Greetings-
I have the part, and we are discussing the procedure.
Will I have to take the door, sides, and top off to access the pump? Or can I simply lift up the top, or perhaps remove just the back panel to access it?
If I need to take it all apart- would simple household tools work to unclamp the drum, or do I need "special" tools for that?
thanks for your help!!!!!!
just tilt it back and lean it against the wall and attack it from underneath
YEEHAH!
HORAYYYYYY!
I am washing my 1st load of laundry! It took us about 45 minutes to fix, with several interruptions from 4 kids and dinner- but we did it! well, actually my hubby did it- I just held the parts.
we did get a few photos- I'll upload them today.
It was easy easy- just like you said it would be.
and it saved us a huge bundle.
I am VICTORIOUS!!!!!!!!!!!!!! and a domestic goddess, to boot! LOL
great job..... give your husband a beer and break out the blender for you!
Do the happy dance :woohoo:
 ..............But I would hang onto the old pump. After reading the old posts, if the hose is pushed down to far into the standpipe and is up against the bottom of the p-trap, it could restrict the volume of the water....
