LG WM1814CW
43 replies to this topic
#21 denrayr
denrayr
  • 1,148 posts
Posted 09 April 2009 - 11:00 AM
just tilt it back and lean it against the wall and attack it from underneath
#22 neehowhenhow
neehowhenhow
    Sōhei
  • Chief Appliantologist
  • 109 posts
  • Flavorite Brew:Pete's wicked
Posted 09 April 2009 - 11:01 AM
YEEHAH!
I embrace that which I cannot change...
Housework RULES!
#23 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 10 April 2009 - 02:40 AM
HORAYYYYYY!
I am washing my 1st load of laundry! It took us about 45 minutes to fix, with several interruptions from 4 kids and dinner- but we did it! well, actually my hubby did it- I just held the parts.
we did get a few photos- I'll upload them today.
It was easy easy- just like you said it would be.
and it saved us a huge bundle.
I am VICTORIOUS!!!!!!!!!!!!!! and a domestic goddess, to boot! LOL
Housework RULES!
#24 Tronicsmasta
Tronicsmasta
    Senpai
  • PipPipPipPip
  • 520 posts
Posted 10 April 2009 - 09:59 PM
great job..... give your husband a beer and break out the blender for you!
It is never a bad thing to leave it to the professionals. Inexperience can lead to more damage or risk of injury. You can always call A&E Factory Service (1-800-905-9505), Sears(1-800-469-4663), or local service man you can trust (servicemagic.com).
#25 certified tech group 51
  • 2,712 posts
Posted 11 April 2009 - 06:32 AM
Do the happy dance :woohoo:
 ..............But I would hang onto the old pump. After reading the old posts, if the hose is pushed down to far into the standpipe and is up against the bottom of the p-trap, it could restrict the volume of the water....
#26 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 13 May 2013 - 01:25 PM
and i resurrect this sucka again!
Now my happy little washer decided to stop spinning. No funny smells or anything. The display says "LE" and it will run, water will come in, and the drum will consider moving, but then changes its mind. and I hear this high pitched sound, like it wants to go, but cannot. Help!
thanks!
aj
Housework RULES!
#27 PDuff
PDuff
  • 2,131 posts
Posted 13 May 2013 - 01:56 PM
LE fault indicates problem with the rotor positioning sensor (hall sensor) or the motor stator.  Check resistance of hall sensor from pin 5 to pin 1 and pin 2.  If sensor is good should read 10k ohms from pin 5 to pin 1 and 10k ohms from pin 5 to pin 2.  If either test shows open circuit, sensor is bad.  The high pitched sound concerns me though.
#28 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 13 May 2013 - 03:19 PM
okay. well, aint got no ohm thing. got to get one.
Housework RULES!
#29 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 13 May 2013 - 03:23 PM
if its the sensor, how easy is it to replace?
Housework RULES!
#30 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 May 2013 - 04:41 PM
have you been using only HE detergent :whistling:
http://www.repaircli...R=154&N=1268237
Rotor-Position-Sensor-6501KW2001A-006849
service manual
http://appliantology...-wm1812-wm1814/
Edited by Samurai Appliance Repair Man, 13 May 2013 - 05:45 PM.
#31 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,244 posts
Posted 13 May 2013 - 05:50 PM
Welcome back, neehow!  Nice to see you again.   :smile:
Remove the back panel from the washer and tighten the center mounting bolt in the back of the drum to cinch up the rotor to the drum splines. If the bolt was loose and the noise continues, then the splined cylinder in the rotor is stripped and you need to replace the rotor assembly.
http://www.repaircli...ER1001C/1267509
Edited by Samurai Appliance Repair Man, 13 May 2013 - 06:23 PM.
#32 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 13 May 2013 - 05:56 PM
Konichiwa Grand Masters! Of course, being the all-powerful mamasan of my personal dojo- I make my own laundry soap...cuz that's how I roll. :turned:
I will take a look at the things you mentoned, well the Boss will actually and i'll report asap.
thanks
aj
Housework RULES!
#33 MicaBay
MicaBay
    Master Roaster
  • 1,087 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 13 May 2013 - 09:38 PM
Making you own soap is okay, only if you see absolutely zero suds inside. Those drain pumps are great at pumping water but terrible at pumping air.
#34 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 14 May 2013 - 06:34 AM
my soap lacks suds, thankfully! I ordered the part- just in case... and HOH will take a look tonight. meanwhile off to the laundrymat with the crew! so fun!!
Housework RULES!
#35 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 16 May 2013 - 01:33 PM
Howdy again- I have the part in hand, and DH is outta town- so it is me fixing this baby. I will check the bolt in the back, but I have to ask...forgive my dinginess- where the eff is this little sensor located? I am searching the manual, and cannot find it! Help!
thanks
aj
Housework RULES!
#36 RegUS_PatOff
  • 33,588 posts
Posted 16 May 2013 - 02:17 PM
#37 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 16 May 2013 - 02:26 PM
I AM VICTORIOUS!!!!!!!!!!!!!!!!!!! :rocker:  :rocker: :rocker:  :rocker:
thanks for the post of info,  I also googled the part and found a video of the thingy- I am washing a load of laundry right now! My 4 girls helped and watched. It took all of about 10 minutes! No noise, and she spins like a whirrling dervish!
Yay Me! I am the queen of my castle!
Thanks guys for the troubleshooting- I can only imagine how much this would have cost me to call a tech in!
DRINKS
ON ME! :dazzler:
Housework RULES!
#38 Samurai Appliance Repair Man
    Shōgun
  • 31,244 posts
Posted 16 May 2013 - 02:57 PM
Congrats on the fix, neehow!
BOOJAH!
#39 neehowhenhow
neehowhenhow
    Sōhei
  • 109 posts
Posted 04 January 2014 - 03:49 PM
aaaah!  this POS washer again. Whenever I put on the hot water, to wash some clothing- the sukkah makes this horrible crazy squealing screeching sound from the water hose coming in, or at least the back of it. Perhaps the machine itself!  It just started doing this a few weeks ago. DH thinks it is cavitating (not sure what that is). Oh something else! Any thoughts?
No sound on "tap cold" wash/rinse which is what I usually do-but the whites get hot water, my mama dun told me...
thanks for the help!
aj
Housework RULES!
#40 john63
john63
    Dean of LG Appliantology
  • 2,223 posts
Posted 04 January 2014 - 05:20 PM
http://www.repaircli...Number=WM1814CW
Verify that the Hot and Cold Water Hoses are NOT the aftermarket stainless steel "FloodCheck/FloodSafe" hoses (malfunctions frequently)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
