FISHYMAN
GE REFRIGERATOR FREEZING UP
11 posts in this topic
I have a GE GSS22QFMCCC side by side refrigerator that just starting freezing up 4 months ago. I had a service guy come up and replace the defrost heater. It was okay for 100 days (10 days after the 90 day warranty gave out) and then starting freezing up again. I have been running a small heater fan inside the freezer area to defrost the unit every 7 days. The coils have a 2-3 in coating of ice.I had the service guy come out again and he ran a quick check with the ohmmeter and opened the refrigerator door in succession 6-7 times to see if the defrost circuit would kick in. He told me that the timer was bad, opened the refrigerator door to look for the timer , could not find it, opened the back lid of the refrigerator and said the circuit board was bad- $250 plus S& H and installation costs. Told him forget it and I ordered it from GE and put it in myself. Still have the same problem though; don't want to get rid of fridge, what can I try next?
:drowning:
Ron
   What was the part number of the heater? It should be on his invoice.   Open the door 6 or 7 times to initiate a defrost cycle? :laughing:  Good one.   The force is saying it's your evaporator thermistor,  Could be the terminator but the numbers still favor the thermistor.
   You had a single heater originally and I'm sure the guy made the dual 442 heater work cause thats all he had.  I hope he used the terminator.  I'm not sure what effect that would have on the micro-contacts on the mother board.  If you study the board for a minute it shouldn't be too hard to find the defrost heater relay.  Does it look or smell toasty.  The only thing that hasn't been changed yet is your evaporator thermistor.
Are you talking about the motherboard installed on the back of the refrig or another board? Where is the defrost heater relay on this board? What is the evaporator thermistor and where is it found?
Gee,  I thought I typed motherboard
The high voltage stuff is near the bottom where the fewer larger wires connect to it.  The low voltage stuff connects near the top of the board where the many smaller wires connect to the board (MOTHERBOARD)
It's the little white thing with white wires clipped to the top left of your evaporator coil.  87% probability this is your defective part.   I am a little concerned about your incorrect defrost heater situation.  If the amp draw is much greater than the original single heater it could damage your motherboard.  Could even take months or years.   I've used the wr51x442 to replace a single heater many times on the older models with a timer but never on a GSS.
Jedi is ezzacly right to be concerned about the excessive current draw on the pother board because of the wrong heater set being used. Sounds like this your parts changing monkey did a hack job on your fridge instead of ordering the correct part because he didn't want to make two trips.
Noticed that the defrost heater was cracked. Ordered new plus thermostat from RepairClinic.
Motherboard was hot to the touch (see attached pic) where the yellow box is- Is this normal?
Besides that nothing else appeared to be burnt or smell hot.
Thanks for all your help so far.
Ron
I also put in a thermometer in the freezer side and noticed that it fluctuated from -20 to 20. Is that normal?
   If I understand you correctly,  you ordered the correct heater harness (single heater with thermostat)  and have not installed it yet and are questioning your freezer temperature fluctuations.
