Frigidaire (PLEB30S8ACB) Oven
7 replies to this topic
#1 rogermaltbie
rogermaltbie
  • 3 posts
Posted 18 April 2009 - 10:02 AM
My Frigidaire oven (Model PLEB30S8ACB) will not heat to desired temperature.  Is this a problem with the EOC?  How difficult are those to replace for a repair misfit? Posted Image
    Shōgun
  • Master Samurai Tech
  • 31,151 posts
Posted 18 April 2009 - 10:43 AM
Does the bake element glow orange or just stay black but feel hot?
#3 rogermaltbie
rogermaltbie
  • 3 posts
Posted 18 April 2009 - 12:27 PM
Initially there was an orange glow, heating the oven but not to the desired temperature.  Now there is no heat or glow from the baking element at all.  The broiler, however, is working.:?
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 April 2009 - 02:24 PM
If you could check the Bake Element with a Volt/Ohm Meter ...
PLEB30S8ACB Wiring Diagram
    Shōgun
  • 31,151 posts
Posted 18 April 2009 - 02:57 PM
Sublime Master Reg gives wise advice, heed his words well and it shall go well with thee.  Just be sure to UNPLUG the range before you even think about removing the element to test it.
#6 rogermaltbie
rogermaltbie
  • 3 posts
Posted 18 April 2009 - 02:58 PM
I stand corrected.  The baking element did heat up after nearly an hour but not to the desired temperature.
    Shōgun
  • 31,151 posts
Posted 18 April 2009 - 03:08 PM
Here's what I'd do if I was on the service call:  in addition to testing the bake element resistance, I would measure the voltage at the bake element power wires.  The latter assignment is what we professionals call a live test.  That means power is on the circuit, voltage and current will be present, fire in the hole, fry yo ace if'n you ain't careful!  So think twice and then once more before proceeding.  Nevertheless, if I was on the service call, that'd be my plan of attack.  Call the ball, Hoss.
#8 RegUS_PatOff
  • 33,588 posts
Posted 18 April 2009 - 03:30 PM
[user=49937]rogermaltbie[/user] wrote:
... The baking element did heat up after nearly an hour but not to the desired temperature.
The Bake Element may have a small crack ...
When set to 350F, what does the read-out say for actual temperature ?
