NellieVA
Keystroke Sequence to Reset Whirlpool Dishwasher
3 posts in this topic
I have a new Whirlpool GU2500XTP dishwasher.  Several weeks ago, the machine quit working and the "clean" LED would blink in sequence seven times.  After several calls to Whirlpool, they advised of a sequence of keystrokes to reset the machine, which worked fine.  I cannot, however, now find that sequence of keystrokes, and the machine is having the same problem.  :yikes:  I do recall that one of the buttons was "Hi-Temp."  Does anyone out there know the correct key sequence?  Thank you!
Let us intone the sacred undemo chords:
high temp - air dry - air dry - high temp
Read thru this whole thread, **the whole thread**, your problem will be addrssed starting part way down, you will need to find the reason this fault code comes up also....
http://applianceguru.com/forum1/2039.html
