jschroter
Oven-wont self-clean
4 posts in this topic
Konichiwa,
The Top oven of my Jenn-Air double oven wont self clean. The bottom oven self clean works just fine.
When i press clean auto-set and clean, the Clean light comes on for 10-20 seconds and then it goes off.  (The Lock and fan never come on)
The users manual says that i should check the Clean and Stop time settings. I am pretty sure there is no delayed clean cycle programmed.
any help is appreciated!
Could be a bad latch switch, bad latch assembly, bad ERC, or bad wiring connector. You'll have to pull it apart and do some poking around with your meter. The wiring diagram is located in the pots drawer compartment, underneath.
While i wait to figure out what to do...is there any product which i can use to clean the oven chemically?  Easy off etc? USers manual suggest not to.
Just spit and determination. Using cleaning chemicals will ruin the finish inside the oven.
