Bosch WFMC 3200 Front Load Washer (WFMC3200UC/01)
  • Replies 11
  • paltoii
  • rickar
  • islamorada
PM your email address ..
manual sent
  • 8 months later...
Hi, I'm looking to replace a door gasket on our Bosch WFMC3200UC , it has a rip in it and is starting to leak. i purchased a gasket kit (door gasket, gasket holder and front/rear gasket clamps) the only instructions that came with it was a service bulletin which doesn't say much. if you can send me a service manual for this washer that would be great. i was planning on trying it this weekend.
thanks again
Thanks for the service manual!
After looking at it, I'm almost ready to go but i just have question regarding the inner seal spring. I looked at the service manual but it doesn't mention anything about the removal of that one. I'm assuming it wraps around the drum or something. If any of you can suggest any tips regarding this inner seal spring before i start that would be greatly appreciated.
Thanks again!
  • 5 weeks later...
  • 3 months later...
Hi,
Could I get the link to the manual as well ?
I replaced the gasket on my washer but one of the clips inside of the door ended up falling into the door when I removed the hinge screws. Is there anyway to open up the door ?? Is there anything in the manual regarding this ?
Thanks,
Kim
Guest
This topic is now closed to further replies.
