danfrsc
Admiral Oven Model 675AK-KVW
4 posts in this topic
My oven only lites part of the time BUT it will start gas the gas without lighting sometimes.
We have had a problem with temp being low by 50 dgrees or so for a year or two also.
I see the glow bar glowing. where do I go now?
Thanks for any help
Dan
Hummmmm, dangerous.  The ignitor opens the gas valve and lights the gas.  If it will not light sometimes and you get gas without the burner lighting I would start by replacing the ignitor and cleaning the burner holes and cross over slit, could be clogged with junk.   The 50* off is probably a different problem, look at the back of your thermostat knob, most of them are adjustable and can re-set the knob to match the difference.
I agree, sounds like a weak igniter. They glow, but they need to draw a certain amperage to bging the gas valve on.
Id start with the ign    .... the gas is the scary part because the amp..  opens the valve.... Hmmmm
