GE Oven Model #J KP86 is not heating up properly but seems to get warm
33 replies to this topic
#1 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 08 June 2009 - 09:19 PM
We have a GE Oven and Microwave combo that worked fine until just recently.  It makes a clicking sound like its going to turn on and then it doesn't.   I turn it off, try again and then it went to 245 and stopped getting hotter (it was set at 350) but it didn't seem like it was at 245--it was warm but not hot.  Any ideas?
    Shōgun
  • Master Samurai Tech
  • 30,905 posts
Posted 09 June 2009 - 03:01 AM
Gas or electric oven?
#3 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 20 July 2009 - 07:19 AM
Sorry been busy--its and electric oven
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 20 July 2009 - 09:58 AM
PM'd    31-9098 Mngrm 27-30 in wall ovens.pdf
#5 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 10:34 AM
Any ideas how to trouble shoot this--its not heating at all--neither element
#6 RegUS_PatOff
  • 33,588 posts
Posted 25 July 2009 - 11:16 AM
Did you check the voltage and connections on the Oven's Terminal Strip
and the house Circuit Breakers ?
Did you check the Oven's Thermal Cutout Switch as mentioned in the Service Manual ?
#7 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 02:35 PM
Ok--its the thermal sensor that is bad--anyone know where that is?
#8 RegUS_PatOff
  • 33,588 posts
Posted 25 July 2009 - 02:56 PM
Double Line Brake Relay ..
not used on model JKP86
#9 RegUS_PatOff
  • 33,588 posts
Posted 25 July 2009 - 02:59 PM
How do you know it's bad if you don't know where it is ?
Oven Thermal Switch (back wall of Oven)
page 35 (PDF page 37) of Service Manual
#10 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:03 PM
Ok--we tested (my brother-in-law did) and we did find a thermostat that was bad--jumped that--still didn't work.  So we jumpered the orange and red lines that go into the L2 (on the main board) and it works.  So at this point we don't know if its the main board that's bad--what steps can we take to isolate the problem?
#11 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:07 PM
In other words the DLB relay is not passing power for the L2 circuit--there is no thermal cutout at the back of the oven because by jumping the DLB (on the main board in the microwave), the oven works fine.  The diagram schematics are not accurate.
#12 RegUS_PatOff
  • 33,588 posts
Posted 25 July 2009 - 05:16 PM
I don't see an a DLB Relay nor Orange Wire on the JKP86 Schematic on page 51,
but page 33 shows the JKP86 uses a DLB Relay.
It dosen't show L2 going to the Board.
Do you have the full model number from the Oven ?
#13 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:42 PM
The schematic is not correct--it shows a inline thermal switch and actually L2 loops through relay DLB (red and orange wires).  We took out the board--see the picture.  When we jump the two wires the oven works fine--leads us to believe maybe the problem is in the DLB relay but my brother-in-law in concerned there may be some other issue.  So how do we know it is in fact the board that's the problem?
#14 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:43 PM
The full model No. is JKP86SOH6SS
#15 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:53 PM
Two wires go into TB2 and TB3--you will note the relay is labeled "DLB" -- when we jump those two wires, the oven words.  Now if I knew the board was the problem, I could just order it but at $100 or so I don't want to order that unless I am sure that's the problem.
My brother-in-law wants to know what controls the DLB relay--doesn't show on the schematic.
#16 RegUS_PatOff
  • 33,588 posts
Posted 25 July 2009 - 05:56 PM
[user=3641]RegUS_PatOff[/user] wrote:
... Do you have the full model number from the Oven ?
#17 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 05:57 PM
BTW--the closest model number I could find to that on the Internet is JKP86SH6SS (missing the "O")
#18 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 06:00 PM
I found the model number on the inside of the microwave (its an oven/microwave combo).  There is no other model number I could find on the oven itself.  Is there another model number for the oven?  I believe the model number inside the MW is for the full combo, isn't it?  If not, where is the model number on the oven located?
#19 ccmulder
ccmulder
    Yamabushi
  • 69 posts
Posted 25 July 2009 - 06:19 PM
BTW--the part number for that oven control is WB27T10500.  If I was sure that was it, I'd just order it.
#20 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 25 July 2009 - 08:31 PM
