LOST
GE STOVE TOP GAS range ... JGP337WEJW
5 posts in this topic
ALL OTHER(3) BURNS) DO LITE (by the way  if I lite a good burner and then turn on the bad one it will lite)
1) HOW DO I MAKE ACCESS TO THE INSIDE OF THIS DROP IN STOVE TOP RANGE
2) after reading much  me thinks the ignitor is bad but  need (all of )your input first
3) please tell me how to access the guts of this unit
it has four(4) screws in back on top but that is all I see
your help is greatly appreciated
thank you all
Check the polarity of the outlet that the range is pluged in to. The reason the burner ignites when one of the other burners is fired up is because part of the circuit is being completed through the flame. Read this article for fun facs to know and tell:
http://fixitnow.com/2004/09/appliance-repair-revelation_17.htm
In order to get you disassembly help, you'll need to post a valid model number.
POLARITY ALL OK
NEXT THOUGHT PLEASE
[user=2687]LOST[/user] wrote:
NEXT THOUGHT PLEASE
Why bother? You are apparently incapable of following simple instructions, such as providing a valid model number, or reading a pertinent article which provides detailed insight into your problem.
You also write in all caps, which means you are either rude or dim-witted. Either way, you are unworthy of my time. Perhaps someone else will waste their time with you.
(edited for typos)
gee thanks alot
key was down sorry
