New way to connect wires
5 replies to this topic
#1 certified tech group 51
  • 1,972 posts
Posted 21 June 2009 - 11:10 AM
  • Somebody left these out side my office door one day, has anyone else used them??
  • Posted Image
  • Posted Image
#2 denrayr
denrayr
  • 1,111 posts
Posted 24 June 2009 - 07:53 PM
i dont like the idea of them. i guess im old fashioned but when i do electrical work i never use the quick connects, i always make a loop and use the screw terminal.
RedRock Appliance Service
435-773-7838
www.redrockrepair.com
Serving St George and Southern Utah
#3 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 04 July 2009 - 07:37 PM
I tried them and didn't like them.
Scott Wolf
#4 volleyball
volleyball
    Ikkō-ikki
  • Master Appliantologist
  • 45 posts
Posted 17 August 2009 - 09:33 AM
I'd hesitate to use them on anything of mine. doesn't look easy to remove and reinsert and what about stranded wires? On my house, I've had 2 of my 115v duplex outlets loose connection on those press in connections. Not my original work and they did last decades but still a pain to find.
#5 neurodoc
neurodoc
    Ikkō-ikki
  • 29 posts
Posted 05 October 2009 - 01:02 PM
These are actually pretty good substitutes for "wire nuts," with two caveats: 1) they take up more volume; and, 2) they can't be easily disconnected, i.e., you should consider them "permanent," unlike wire nuts that can be unscrewed. I use them mostly in running cable through a series (actually it's a parallel circuit) of recessed ceiling lamps. The bulkier nature of these connectors is actually compensated by the fact that you don't need to run a "pigtail."
The only question I have regards the "ampacity" of the copper clips in this device. It may not be beefy enough to handle high loads...but I don't worry about that for lighting circuits.
#6 Tim M
Tim M
    Kohai
  • Scholar of Appliantology
  • 324 posts
Posted 11 January 2010 - 05:37 PM
Something like them came with some outlet strips I installed, they were a huge hassle, but nothing else would fit inside. Next time I'll put a box at the end of the strip so I can use good old-fashioned wire nuts that can be disconnected!
