jrhexp
GEGTS22ICMBRWW
6 posts in this topic
Hi, Noticed my fridge was warm. Checked and found evap coil iced up defrosted and put back on line fan and compressor came on for a while then just stopped. Any one know sequence of magic board in back of fridge? What resistance should sensors read? Thanks for a great fourm.
For the thermistors, just check to make sure they're not open. Set your meter to Rx1K and check the continuity that way-- they actual resistance is not important since these devices fail open.
See this thread for more discussion on your problem.
Just an update.Checked the resistance of the thermistor's none were open. Sometime after that while I was at work contemplating whether or not to spring for a new main board the thing started to work and has been for a day or so??????????
Cannot get that model number to come up, is this a G.E.?  If so the thermisters have known problems so might not be a bad choice to replace all of them, might be 2-3 in there, so not know since cannot pull up this box.  Re-check that model number.
LOL, I was using the whole number with the GE in front, did not think to seperate that from the model number.....dah......;)
