DStearns
Hotpoint CTX21ELJ refrig worse after my repair
5 posts in this topic
I determined, with your help, that I had a defrost problem with a Hotpoint CTX21ELJ refrigerator and decided to replace the defrost thermometer and timer. The heating element had continuity, so back in it went. I purchased parts directly from GE and now that I have installed them, the unit will not turn on at all.
1. Yes, I plugged it back in.
2. Yes, there is power (the light is on).
I can also feel the timer faintly humming, so that seems to work. I can stick the probes of the multimeter into the conenctors that spliced the new thermostat in place and there is continuity, so that switch is closed at room temperature.
I checked all the wire harnesses and plugs and everything seems tight.
Maybe the mistake was cleaning it while all the food was out.
How do I proceed to troubleshoot this beast?
Timer is in defrost mode. Will have probably timed out and switched over to run mode by the time you read this reply.
See? Told ya. :P
Indeed you were right, sensei.  But I did cheat a little.  After your reply I went back, plugged in the unit, and manually advanced the timer, which only needed to turn about 5 degrees before the compressor turned on.  Thanks for the help.
:rocker:
