hugosa
Can't find faulty code F6E4 for Kitchenaid... anywhere
8 posts in this topic
I just bought a Kitchenaid Gas Range slide in stove. After 1 day of use, the control panel started displaying an error code F6E4. I can't seem to find this code anywhere online.
Does anyone know where I can find a complete list of error codes for Kitchenaid, including their new 4-digit codes that start with F6?
Thanks in advance,
Hugo
It is in the tech sheet that is somewhere in your range.....without a model number I cannot find this for you either.
Hi,
I have looked everywhere but I can't find a technical sheet - I don't think I got one with the stove.
The model number of my gas range is KGSA906.
Thanks.
Hugo
possible bad power board, or bad wire conector issue, or a display board, If the error occurs again, restart the troubleshooting procedure at step A (except
in step D replace the display board if power board has already been replaced
F6
Systems
E4 LOST COMMUNICATION
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart on page 5 to
enter the Diagnostic mode.
A. Unplug range or disconnect power.
B. Open the back panels and make sure the P2 connector is fully plugged in on the
power board and on the display board.
If it is not, plug it in to the connector and go to step F.
If it is plugged in, go to step C.
C. Visually inspect all the four wires between P2 on the power board and P2 on the
display board. Make sure the wires are not cut or pinched. If the wires appear
to be intact, perform a continuity check between pin 4 of the power board and pin 4
of the display board. Do the same for pins 1, 2, & 5. Both of these checks should
result in a reading of less than 5.
If either of these checks fail, go to step E.
If these checks pass, reconnect P2, then go to step D.
D. Replace the power board. Ensure all connectors are properly seated and then go
to step F.
E. Replace the wiring harness (signal) and go to step F.
F. Ensure all wiring connections are made. Replace the back panels.
G. Plug in range or reconnect power. Observe for longer than 1 minute.
H. If error does not appear, initiate a bake cycle. Let the cycle run at least 1 minute.
If no error occurs, cancel the cycle. The problem has been repaired.
in step D replace the display board if power board has already been replaced)
SOUNDS LIKE YOU NEED TO CALL FOR WARRANTY SERVICE........:shock:
[align=left]FAILURE[/align]
[align=left](Leftmost[/align]
[align=left]2 Clock[/align]
[align=left]Digits)[/align]
[align=left]ERROR[/align]
[align=left](Rightmost[/align]
[align=left]MESSAGE/DESCRIPTION[/align]
[align=left]SUGGESTED CORRECTIVE ACTION PROCEDURE[/align]
[align=left]F6[/align]
[align=left]Systems[/align]
[align=left]E4 LOST COMMUNICATION[/align]
[align=left]PROCEDURE: Before proceeding, perform steps 1 through 3 above chart on page 4 to[/align]
[align=left]enter the Diagnostic mode.[/align]
[align=left]A. Unplug range or disconnect power.[/align]
[align=left]B. Open the back panels and make sure the P2 connector is fully plugged in on the[/align]
[align=left]power board and on the display board.[/align]
[align=left]If it is not, plug it in to the connector and go to step F.[/align]
[align=left]If it is plugged in, go to step C.[/align]
[align=left]C. Visually inspect all the four wires between P2 on the power board and P2 on the[/align]
[align=left]display board. Make sure the wires are not cut or pinched. If the wires appear[/align]
[align=left]to be intact, perform a continuity check between pin 4 of the power board and pin 4[/align]
[align=left]of the display board. Do the same for pins 1, 2, & 5. Both of these checks should[/align]
[align=left]result in a reading of less than 5 Ω.[/align]
[align=left]If either of these checks fail, go to step E.[/align]
[align=left]If these checks pass, reconnect P2, then go to step D.[/align]
[align=left]D. Replace the power board. Ensure all connectors are properly seated and then go[/align]
[align=left]to step F.[/align]
[align=left]E. Replace the wiring harness (signal) and go to step F.[/align]
[align=left]F. Ensure all wiring connections are made. Replace the back panels.[/align]
[align=left]G. Plug in range or reconnect power. Observe for longer than 1 minute.[/align]
[align=left]H. If error does not appear, initiate a bake cycle. Let the cycle run at least 1 minute.[/align]
[align=left]If no error occurs, cancel the cycle. The problem has been repaired.[/align]
[align=left]If the error occurs again, restart the troubleshooting procedure at step A (except[/align]
[align=left]in step D replace the display board if power board has already been replaced).[/align]
[align=left]E5 CANCEL KEY ERROR[/align]
[align=left]PROCEDURE: If step 2 above chart on page 4 has not been performed, perform steps[/align]
[align=left]2 and 3 to verify error. If error persists, replace the display board.[/align]
[align=left]PART NO. 9757665[/align]
[align=left]NOTE: This sheet contains important Technical Service Data[/align]
[align=left]FOR SERVICE TECHNICIAN ONLY[/align]
[align=left]DO NOT REMOVE OR DESTROY[/align]
You called this one right.
Just as a FYI, I got this same code two days after mine was installed.  Tech said the motherboard was bad, need a new one.
(I made Sears drag that dishonorable range back to the warehouse and send me a new one...which proceeded to die one day after the warranty expired when I tried to use the self-clean feature.  Shut down entirely, no more oven.
But that is a different story...)
Guest
This topic is now closed to further replies.
