Whirlpool Duet Washer WFW8300SW04
sbdivemaster
sbdivemaster
Anyone have a PDF for the Whirlpool Duet Sport WFW8300SW04 Service Manual?
Thanks in advance.
  • sbdivemaster
  • grey shrek
sbdivemaster
You da man, RegUS!
Had my first scare with the brand new machine.  Less than 6 months old, and it's already acting funny.
Over the weekend, we went to run a load, and it started making a buzzing/rattling sound from the fill area and no water was going into the machine.  I checked the inlet lines, but they were clean.  Tried to start the machine several times, but still the same thing every time.
Called in a Whirlpool service guy for Monday.  Checked it again Monday morning and still had the problem.
Of course, when the guy arrived that afternoon, it worked absolutely fine!  Grrr...
After I told him about the old Maytag Neptune (yeah, THAT one), and how I fixed it, he was all excited.  He advised me to clean out the drain hose after the pump every six months or so.  His description sounded easy, but I wanted to be able to check out some diagrams before attempting.
I appreciate the speedy response, and the manual will help me out with that little project this weekend.
Thanks for the help, and the link to the service manual.
:cheers:
