Evaporator Fan not Turning
  • This topic is locked This topic is locked
11 replies to this topic
#1 Dodger
Dodger
  • 6 posts
Posted 31 March 2005 - 12:54 PM
I have a problem with a not-cold refrigerator section and a freezer that does not cool evenly. I had ice building up on the back corner of the freezer. I removed the panel at the back of the freezer and found more ice above the coils in the corner. I let everything defrost and plugged it back in. It cools good, but ices up again. I noticed the evaporator fan is not turning. I assume the fan should be on at all times.
Is my assumption correct? Is the evaporator fan to be moving air at all times?
If the fan is not working, is there something else besides a bad fan that could cause the fan not to run.
If it matters it is a Kenmore (build by Whirlpool) freezer on top, model 106.8682880.
Mike
  • 24,692 posts
Posted 31 March 2005 - 12:59 PM
Did you have ice built up in one corner only, like in the pic below:
Or was the ice caked evenly on the whole evaporator coil?
#3 Dodger
Dodger
  • 6 posts
Posted 31 March 2005 - 01:14 PM
Just like in your photo. Ice in the upper left hand area (mostly on the wires).
  • 24,692 posts
Posted 31 March 2005 - 01:27 PM
Bad news, compadre:  you got yerself a sealed system problem.  It's either an inefficient compressor or the sealed system has leaked.  Either way, it's a world of hurt.  Probably not worth fixing, you're better off going shopping.
#5 Dodger
Dodger
  • 6 posts
Posted 31 March 2005 - 02:13 PM
Thanks for the quick response. The fridge is 17 years old, so I guess it's time to replace it.
  • 24,692 posts
Posted 31 March 2005 - 02:20 PM
Hold on there, Bubbalouie! I'm re-reading this thread and it occurs to me that perhaps I've been too hasty in my condemnation of your fridge. There's a chance that the evaporator fan is the root of all evil here. See if the fan is getting voltage-- you may need to press the freezer door switch in while doing this to make sure you're measuring under the right conditions. If you're getting voltage to the evap fan but it ain't turning, then the odds are much greater that the evaporator fan is your problem and not the sealed system. Much less expensive than buying a new fridge!
Sorry about the confoosion.
#7 Dodger
Dodger
  • 6 posts
Posted 01 April 2005 - 03:58 PM
Now you tell me!
I just finshed putting the whole thing back together. I will take it apart tomorrow and check the voltage to the fan. If the voltage is bad, what would be my next step?
One good thing about taking it apart is that it is now really clean. Of course I ended up with four screws left over. I figured out where they go after I reassembled it.
On a unrelated issue, how do I remove the 'floor' of the freezer. In the past, I have had to unclog the freezer drain to avoid water in the frig part and it is getting clogged with paint that has flaked off the back panel and has accumulated under the 'floor'.
Thanks a lot for your help.
  • 24,692 posts
Posted 01 April 2005 - 04:05 PM
Now you tell me!
I posted my last reply a scant seven minutes after your last reply!  ;)
I wouldn't expect the voltage to be bad but rather the voltage to be good and the fan motor bad.  It's possible the voltage would be bad (non-existent or something far less than 120vac == junk voltage), just less likely.  Measure it and lemme know whatcha get.
Post your model number so I know what breed you gots.
#9 Dodger
Dodger
  • 6 posts
Posted 01 April 2005 - 04:58 PM
  • 24,692 posts
Posted 02 April 2005 - 02:35 AM
You don't need ton nremove the freezer floor, just the back:
#11 Dodger
Dodger
  • 6 posts
Posted 02 April 2005 - 12:22 PM
The voltage going to the fan is 120. I applied 120AC to the fan on my workbench and all it did was hum. The fan is dead.
#12 Samurai Appliance Repair Man
  • 24,692 posts
Posted 02 April 2005 - 12:33 PM
Thar she blows!  You found the el problemo-- nice shootin', Hoss.  Bad evaporator fan will cause trouble in doggie land.  Come git you one.
