Bosch SGS 4012 GB Dishwasher service manual request
compuphonic
  • compuphonic
I don't have that one..
Bosch info is hard to get
compuphonic
Ok thanks.
Any idea of these units have an internal fuse ? There is no voltage reaching the door mounted power switch.
Looks like I need to disassemble the base by removing the front kicker area..
looking at a few other models, the Line power connects directly to the Door Switches ...
... have you checked the power connections behind the Toe-Kick Panel ?
Those Wire-Nuts get loose, corroded, etc...
click on picture
