Amana Oven - ignitor lights, burner starts heating, then entire unit powers off!
7 replies to this topic
#1 fred_perkins
fred_perkins
  • 14 posts
Posted 10 August 2009 - 09:02 AM
Amana gas range, model ACS3350.   A few seconds after pressing "Bake" button and setting temperature, ignitor lights up just fine and amp draw is within range.  About 20 seconds later, gas starts flowing (hiss is easily heard) and burner lights with steady blue flame.  Ignitor STAYS ON as oven heats.
After about a minute (heat usually gets up to around 300 F), a "click" sound is heard and then the entire unit powers itself off!  Ignitor goes dark, LED display goes dark, and about 3 seconds later the gas stops flowing (hissing stops).
Breaker does NOT trip, and the unit will turn itself back on (clock flashing on display) after a minute or so.  HELP!  Suggestions?
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 10 August 2009 - 09:17 AM
Sounds like your oven controller (EOC) is kickin up a fuss
#3 fred_perkins
fred_perkins
  • 14 posts
Posted 10 August 2009 - 09:27 AM
No F codes are ever displayed.  Should I bother checking sensor resistance (at room temp)?
#4 kdog
    RoughShod
  • 7,474 posts
Posted 10 August 2009 - 09:41 AM
Look for some charred components in the controller
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 August 2009 - 09:53 AM
Oven Thermostat controls the Oven Ignitors.
The Ignitor stays ON while the Gas is ON.
yes, does sounds like a flaky ERC, but check ACS3350 Technical Bulletin
ACS3350 Wiring Diagram
#6 fred_perkins
fred_perkins
  • 14 posts
Posted 10 August 2009 - 10:25 AM
Can't tell whether autolatch assembly was replaced or not, but customer says that the controller was replaced once, in 2005 or 2006.
I find no charred components whatsoever on either PCB of the controller that is installed presently.
There are four electrolytic capacitors: 3300 microF, 470 microF, another 470 microF, and a 100 microF.  All look clean, but haven't checked any of them.
#7 fred_perkins
fred_perkins
  • 14 posts
Posted 10 August 2009 - 10:54 AM
Believe it or not, the problem was actually caused by a flaky wall outlet!  I happened to jiggle the wall plug and noticed that the LED display powered on and off.  Tried another nearby outlet, and VOILA -- no more mysterious shutoffs!
Apparently, as the oven would heat up, some heat lost through the back panel would cause a main power break at the wall outlet.  I'm advising the customer to have an electrician replace the outlet and check the wiring in the wall.
#8 kdog
    RoughShod
  • 7,474 posts
Posted 10 August 2009 - 11:03 AM
Good Job!!
