service manual for friggy GLES 389 ESA
certified tech group 51
service manual for friggy GLES 389 ESA The unit is flashing code F-30...  No bake and no broil, no self clean...... sensor tested 1096 ohms...... checked the resetable thermal fuse.,  test....O.K..........No other info found on the rear of the range...... Frigidaire closed their site?? only for people with log-on and passwords ??.
  • Budget Appliance Repair
  • certified tech group 51
Deleted...... since RegUS PM the info. I probably should have PM'ed it myself, sorry.
